Google assistant and IFTTT - custom phrase won't work
Hi! I have integrade IFTTT with my hass.io so I can create custom phrases for my Google assistant. Everyting works good if I use botton widget. But when I try to use a custom phrase it won’t work.
I have tried to unlink and relink my accont to IFTTT in the app and also in hass.io - but with no effect. I have also checked that IFTTT has premisson to reach voice from Google home.
I have set Swedish and English as language i Google home.
Someone that have had the same problem?
Is there any delay in the sync between Google home and IFTTT?
There is an delay indeed but it should work.
Maybe there is some confusion when having dual languages?
I also had dual languages for a short while (Swedish and US English) but changed back to US English only.
What kind of actions do you want to activate with IFTTT?
Another take on this is to create a scene or switch and expose them to GH/GA.
In the swedish version of google home I can’t use routines so I was hoping to avoid using “slå på morgonbelysning” and more using a phrase like “God morgon” and then a automation (with light, coffe and radio) is fired in hass.io.
If you create the scenario in hassio and expose that to GH you can acivate by saying “aktivera godmorgon” or what the exposed domain is called.
Here is all domains that is possible to expose to GH https://www.nabucasa.com/config/google_assistant/
That’s great!
But I only wan’t to say “godmorgon”, “titta på tv” etc to activate a automation in Hass.io. And i thought this could be possible if i use IFTTT to link google assistant to hass.io. Is this possible?
As far as i know IFTTT doesnt handle Swedish yet.
As for now i am using routines from GH but thats not available in Swedish yet either :frowning:
I have tried to make “mine” understand swedish the solution i found was to use scripts and name it in swedish, but it is a rely bad solution, google home will say “Okej slår på xxxxx” since we don’t have rutins in Sweden as of today.
with IFTTT I haven’t found a swedish solution.
I wouldnt be surprised if routines is launched in Sweden before IFTTT have a solution for Swedish
