I am having trouble to select the right API key for Google Assistant…
can someone help me out?I think the right one is the one called API Key 3.
You also need the right Project ID and your HA to be accessible from internet with a valid ssl certificate.
Regards
Well, I am using that one, rebooted HA (got SSL etc). Google Home works but won’t sync new devices…
This is the error I find in the logs:
2018-12-09 13:42:01 ERROR (MainThread) [homeassistant.components.google_assistant] request_sync request failed: 400 b’{\n “error”: {\n “code”: 400,\n “message”: “API key not valid. Please pass a valid API key.”,\n “status”: “INVALID_ARGUMENT”,\n “details”: [\n {\n “@type”: “type.googleapis.com/google.rpc.Help”,\n “links”: [\n {\n “description”: “Google developers console”,\n “url”: “https://console.developers.google.com”\n }\n ]\n }\n ]\n }\n}\n’
I’m having the same problem as @JanLankhorst. Can’t sync devices with google_assistant.request_sync command. The only solution that i found is to unlink and relink the [test]app. The SSL is good and Google Home work’s. Any solution would be appreciated.
I did the procedure again and upgrade HA to the latest version… Solved the problem and has been working ever since.
