Good evening,
i am working on a multiuser Smart Home App.
This app does not require you to set up your own Google Cloud Project.
The only thing you need to enable for this app to work, is to have your API reachable from the outside, for example through DuckDNS. Make sure its set up for https as well for security reasons.
until now i implemented:
lights
switches
groups
automations
scripts
[update 2/25/2018]
Added: Selective entities (you can select what entity to control in the app now, this was requested by @anon35356645 )
Added: RGB bulbs (if they have supported feature 127).
[update 2/26/2018]
User handling changed: Please re-link app.
for now you can turn on and off lights, switches, groups, scripts, automations.
you can set brightness of lights
you can set temperature of lights if supported
you can change the color of lights if supported
If you want to test the app, let me know. ( send me a PM with your gmail )
The app will ask you for your url and api_password to your hass instance.
for example:
API_URL: https://my-hass-url.tld:PORT/ or https://my-hass-url.tld/
API_PASSWORD: here you need to add the api_password what you have set in your configuration.yaml
(this is getting stored encrypted in our Database)
What about if I want to expose only some entity_id and not all?
I tried your app and I added LIGHTS, but those are already linked with the Google Assistant HA component, so of course it duplicated the same item, plus added all the LIGHTS that I have not enabled with HA component.
Also please can you explain the difference with the HA googla assistant component ?
@anon35356645 thanks for testing. This app is meant for people who do not want to start their own Google Actions Project, so if you use my app, you don’t need the HA Google Assistant component. The selective entities is a good idea. i will look into this.
Notice: Undefined index: entity_id in /var/www/virtual/controlthe.space/htdocs/authorize.php on line 308 Warning: Invalid argument supplied for foreach() in /var/www/virtual/controlthe.space/htdocs/authorize.php on line 308
Hi!
To connect your Home Assistant,
please sign in!
Notice: Undefined variable: output in /var/www/virtual/controlthe.space/htdocs/authorize.php on line 335
