2018-01-07 01:20:42 INFO (MainThread) [homeassistant.components.google_assistant.auth] user login in from Google Assistant
2018-01-07 01:20:46 INFO (MainThread) [homeassistant.components.http] Serving /api/google_assistant to 66.249.93.16 (auth: False)
in the Google Assitant app i klick + it start the adding but goes back without a error.
You need to follow the instructions very(!) precisely. It explains how to generate the access_token and where to put it. If you haven’t seen this you did not follow the instructions
2018-01-12 22:20:26 INFO (MainThread) [homeassistant.components.google_assistant.auth] user login in from Google Assistant
2018-01-12 22:20:28 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 95.8x.8xx.2x9 (auth: False)
same error
i got the following fields:
google_assistant:
project_id: hassio-504f3
client_id: 818853308761-2170r7sssssss4asj5p5.apps.googleusercontent.com from google could console
access_token: sB4d9AeDFtCssssssssuyfLDsExQo self build like in the tut
agent_user_id: [email protected] my googleaccount
api_key: AIzaSyBoFkDsssssssM_cNtuXN5V1oI key from could console for homegraph
exposed_domains:
- switch
- light
- group
