Google Assistant auth error
Hi
i followed https://home-assistant.io/components/google_assistant/
but cant get it work.
this is my config.yaml
google_assistant:
  project_id: home-assistant-57457
  client_id: 1043828045855-ohkql30cxxxxxxxxxhm0e2llatg6775m17.apps.googleusercontent.com
  access_token: mJAdfmkMexxxxxxxxxxxxxxxk8opc4mQ7sqxjnurMO9mS9mWRUvVttuHwkXPIE1mK9bjXpT
  agent_user_id: mJAdfmkMxxxxxxxxxxxxxxxdXkfLeJWk8opc4mQ7sqxjnurMO9mS9mWRUvVttuHwkXPIE1mK9bjXpT
  api_key: 1043828045855-ohkql30c6xxxxxxxxllatg6775m17.apps.googleusercontent.com
  exposed_domains:
    - switch
    - light
    - group
and got this error
2018-01-07 01:20:42 INFO (MainThread) [homeassistant.components.google_assistant.auth] user login in from Google Assistant
2018-01-07 01:20:46 INFO (MainThread) [homeassistant.components.http] Serving /api/google_assistant to 66.249.93.16 (auth: False)
in the Google Assitant app i klick + it start the adding but goes back without a error.
Any Idea?
in Google
https://console.actions.google.com
i only got this client-id entered and no apy key or something
No one can Help me ? I dont Knowhow this Dosentomaten Work.
Where do i Put the acces_token ?
The only Thing i hot in Hass and Google ist clientid
You need to follow the instructions very(!) precisely. It explains how to generate the access_token and where to put it. If you haven’t seen this you did not follow the instructions :wink:
I generated it. And Put IT in the config. But nowhere Else. Where is the 2cond Point to Put IT ?
I Made it 3 Times and all ends in the auth Error because someone didnt Work.
so i made it totally new:
2018-01-12 22:20:26 INFO (MainThread) [homeassistant.components.google_assistant.auth] user login in from Google Assistant
2018-01-12 22:20:28 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 95.8x.8xx.2x9 (auth: False)
same error
i got the following fields:
google_assistant:
project_id: hassio-504f3
client_id: 818853308761-2170r7sssssss4asj5p5.apps.googleusercontent.com from google could console
access_token: sB4d9AeDFtCssssssssuyfLDsExQo self build like in the tut
agent_user_id: [email protected] my googleaccount
api_key: AIzaSyBoFkDsssssssM_cNtuXN5V1oI key from could console for homegraph
exposed_domains:
- switch
- light
- group
i have NO idea where my fualt is :frowning:
