casperse
(Casperse)
February 22, 2020, 8:52am
1
Hi All
I just did the update and I did read the breaking changelog:
Google Assistant - Entities exposed to Google Assistant, that have aliases configured (YAML only feature), will now expose the configured name, instead of the first configured alias.Because of that, it might be that entities that have a name and aliases set for Google Assistant, may show up with a “new” name.This mitigates an issue with Google Assistant, which seems to ignore the configured name when aliases are configured. - (@frenck - #30799 ) (google_assistant docs )
I just cant find anything changend in the guide of the manual setup of Google assistant?
Is there a easy fix to this that I didnt find during search?
Casperse
Just put a name: for every exposed entity, and you should be fine
casperse
(Casperse)
February 22, 2020, 10:41am
3
Could you give me an example?
A name in the configuration file?
google_assistant:
project_id: !secret gass_projectid
api_key: !secret apikey
exposed_domains:
- sensor
- script
- switch
- light
- climate
- cover
- media_player
- scene
- group
- fan
expose_by_default: false
entity_config:
climate.temperatur_i_haven:
room: Haven
expose: true
aliases:
- Temperatur i haven
# sensor.havetemperatur:
# name: Havetemperatur
# room: Haven
# expose: true
# aliases:
# - Temperatur i haven
climate.temperatur_i_garagen:
room: Garage
expose: true
aliases:
- Temperatur i garagen
# sensor.garagetemperatur:
# name: Garagetemperatur
# room: Garage
# expose: true
# aliases:
# - Temperatur i garagen
# cover.garagedoor:
# name: Garageport
# expose: true
# room: Garage
# aliases: Garageport
cover.garagedoor_mqtt:
expose: true
room: Garage
aliases: Garage-port
light.udendorslys:
expose: true
room: Haven
aliases: Udendørslys
# light.lys_i_stuen:
# name: lys_i_stuen
# expose: true
# room: Stue
# aliases: Lys i stuen
# light.lys_i_kokkenet:
# name: lys_i_køkkenet
# expose: true
# room: Køkken
# aliases: Lys i køkkenet
light.thomas_kontorlampe:
expose: true
room: Thomas værelse
aliases: Thomas kontorlampe
light.victoria_kontorlampe:
expose: true
room: Victoria værelse
aliases: Victoria kontorlampe
switch.sonoff_b1:
expose: false
switch.sonoff_b3:
expose: false
switch.sonoff_pow_r2_1:
expose: false
switch.sonoff_pow_r2_2:
expose: false
# switch.sonoff_s201:
# name: Køkkenlampe
# expose: true
# room: Køkken
# aliases: Køkkenlampe
# switch.sonoff_s202:
# name: Gulvlampe
# expose: true
# room: Stue
# aliases: Gulvlampe
# switch.sonoff_s203:
# name: Standerlampe
# expose: true
# room: Stue
# aliases: Standerlampe
switch.sonoff_s261:
expose: true
aliases: Victorias Kontorlampe
switch.sonoff_s262:
expose: true
aliases: Thomas Kontorlampe
switch.sonoff_s263:
expose: false
switch.sonoff_s264:
expose: false
switch.sonoff_s265:
expose: false
switch.sonoff_s266:
expose: false
switch.sonoff_th16_1:
expose: false
switch.sonoff_th16_2:
expose: false
switch.sonoff_4chpro1:
expose: false
switch.sonoff_4chpro2:
expose: false
switch.sonoff_4chpro3:
expose: false
switch.sonoff_4chpro4:
expose: false
script.garageport_alarm:
expose: false
script.sonos_say:
expose: false
script.aktivitetsrum_off:
expose: false
script.musik_stuen_activity_off:
expose: false
script.ps4_activity_off:
expose: false
script.stuen_off:
expose: false
script.chromecast_aktivitetsrum_off:
expose: false
script.tv_stuen_activity_off:
expose: false
script.wii_aktivitetsrum_off:
expose: false
script.musik_stuen_activity_on:
expose: false
script.ps4_activity_on:
expose: false
script.chromecast_aktivitetsrum_on:
expose: false
script.tv_stuen_activity_on:
expose: false
script.wii_aktivitetsrum_on:
expose: false
casperse
(Casperse)
February 22, 2020, 11:01am
4
Got it
Named EVERYTHING even the disabled ones!
And removed the API key no errors…have to check if everything works
