I noticed that I am getting a large number of errors in my log from the google assistant integration. That being said, the integration does appear to be working properly regardless. Is this something to be worried about?
Logger: homeassistant
Source: components/google_assistant/http.py:54
First occurred: 2:19:12 AM (1 occurrences)
Last logged: 2:19:12 AM
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.8/site-packages/jwt/algorithms.py", line 205, in prepare_key
key = load_pem_private_key(key, password=None, backend=default_backend())
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/primitives/serialization/base.py", line 18, in load_pem_private_key
return backend.load_pem_private_key(data, password)
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 1243, in load_pem_private_key
return self._load_key(
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 1472, in _load_key
self._handle_key_loading_error()
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 1526, in _handle_key_loading_error
raise ValueError("Could not deserialize key data.")
ValueError: Could not deserialize key data.
File "/usr/src/homeassistant/homeassistant/components/google_assistant/report_state.py", line 80, in inital_report
await google_config.async_report_state_all({"devices": {"states": entities}})
File "/usr/src/homeassistant/homeassistant/components/google_assistant/helpers.py", line 172, in async_report_state_all
await gather(*jobs)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/http.py", line 204, in async_report_state
await self.async_call_homegraph_api(REPORT_STATE_BASE_URL, data)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/http.py", line 179, in async_call_homegraph_api
await self._async_update_token()
File "/usr/src/homeassistant/homeassistant/components/google_assistant/http.py", line 153, in _async_update_token
_get_homegraph_jwt(
File "/usr/src/homeassistant/homeassistant/components/google_assistant/http.py", line 54, in _get_homegraph_jwt
return jwt.encode(jwt_raw, key, algorithm="RS256").decode("utf-8")
File "/usr/local/lib/python3.8/site-packages/jwt/api_jwt.py", line 64, in encode
return super(PyJWT, self).encode(
File "/usr/local/lib/python3.8/site-packages/jwt/api_jws.py", line 113, in encode
key = alg_obj.prepare_key(key)
File "/usr/local/lib/python3.8/site-packages/jwt/algorithms.py", line 207, in prepare_key
key = load_pem_public_key(key, backend=default_backend())
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/primitives/serialization/base.py", line 23, in load_pem_public_key
return backend.load_pem_public_key(data)
File "/usr/local/lib/python3.8/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 1273, in load_pem_public_key
