So I’m trying to get my ring door bell integrated into google assistant. I have the ring integration setup and everything works inside HA. When I go to the google assistant setting where I can expose entities it doesn’t show any of my ring entities. I have been digging through but can’t seem to get it to show them. Any help would be great
I’m not sure what you are referring to here. What gets exposed to the google home app is configured in yaml. Check the right domains or entities are exposed.
If you have ensured your ring entities should be exposed perhaps the relevant domain is not supported Google Assistant - Home Assistant (home-assistant.io)
I assume you are using Nabu Casa here? What entities from ring are you trying to expose?
The reason I ask is most of the entities I have from ring are sensors so they can’t be exposed as google doesn’t / can’t use sensors.
Well to explain what I’m doing is. I have 4 cameras and a Ring doorbell. I have it setup right now where I can tell my nest hub to show me the back yard. It uses my unifi protect cameras integration. I exposed the stream entities for the cameras to google to allow it stream them when I ask. I was trying to make it so I could say show the the front door and it would grab the live stream on the doorbell cam.
How are you connected to google assistant? what is your configuration?
