Google Assistant Errors
I’ve had Google Assistant configured with Home Assistant for a few years now. To my knowledge I haven’t changed anything recently that would affect this integration. I have Google Assistant configured manually, without Home Assistant Cloud.
I have about 250 entities exposed to Google Assistant. Recently all but just a handful of them started experiencing various errors, with the overwhelming majority of them show as “offline” in the Google Home app. A few multi-layer nested light groups do work for basic on / off, but that’s it. I have lights, vacuums, and climate entities exposed. Attempting to control an entity results in “Something went wrong” in the Google Home app.
Looking in the Google Cloud console I see 2 errors over and over again.
GAL_NOT_FOUND
and
Agent responded empty JSON.
Looking at Google’s troubleshooting documentation, GAL_NOT_FOUND indicates expired access tokens. I re-created the API key for the service account, deleted the account credentials in HA, and unlinked and re-linked the “works with google” app in the Google Home app, yet I’m still getting these errors over and over.
Testing a handful of entities in the Google Home Developer Console passes with flying colors. I can see the devices being manipulated by Google Assistant in HA in realtime.
Once I started trying to fix the Assistant side, the Nest integration also stopped working. Nest would work for about 5 minutes, reporting states and allowing control, then it would fail, complaining about access tokens being invalid.
Bump. I’m getting desperate. The WAF is dropping like a rock
I have 260 entities exposed to Google, but I do have Nabu Casa to ease the setup. That works without a hitch, so the number of exposed entities should not be a problem.
I’d probably check if the certificates are still valid and try the obvious ‘no clue if it helps but try just to be sure’ things like restart HA and the router/modem.
Have you also checked if Google itself or other services such as DuckDNS might have problems in your region?
I ended up nuking the GCP project and device control project and configured everything again from scratch. It’s working now. I think my project was getting throttled / banned.
I’ve just started getting these errors. Has it been stable for you since you nuked it? I’m gonna leave it overnight but tomorrow might be nuke day for me.
It had something to do with Nest. I got rid of my Nest thermostat and decommissioned it in the device console and now Google Assistant is stable.
