Can someone tell me why my google assistant isnt doing anything? here is my log.
Ive followed the guide on home-assistant.io and ive got the json file in place.
It also wont allow me to link it to my google account. When i click open web ui, it just does nothing.
I have the same problem except mic and speaker setup.
Try
“mic”: “1,0”,
“speaker”: “0,0”,
“client_secrets”: “google_assistant.json”
for the mic setup…
I have the same error
[Info] Install/Update service client_secrets fil
Google assistant “lady” tells me that “quote” There is some basic settings that need my permission in the google home app. Why??
Settings in https://myaccount.google.com/activitycontrols?pli=1 are set due to instruction.
ok so im not sure whats going on… but its working… even before just for fun i changed the mic setting to 1,0, and now whenever i say ok google, its working. but it doesnt show anything in the logs or anything… its kinda weird. but it works.
Strange! Is it normal that you can’t enter “web ui” after you pasted in the authorization code?
For me Google Lady still says that “There is some basic settings that need my permission…”
Absolute noob (don’t understand coding) using an iMac to access new Rasbian on Rasberry Pi 3. I added the Google Assistant add-on but when I try to open the Web UI, I only receive an error message site cant be found.
The address it goes to: http://hassio.local:9324/ correlates with Network ( Container 9324/tcp ) Host (9324).
