I’ve searched for activate something in Home Assistant by voice through Google Assistant (Nest hub) in Node-Red but can’t find any examples. I’ve found something with Speech-To-Text & node http-in but don’t understand it. Can anybody send my an example?
I’m not interested in Alexa, addin Almond or Ada.
Thanks !!
This is what I’m searching for.
I will try this.
Hopefully i can combine this flow with HarmonyHub to activate an activity.
Hi mbonani,
I’ve tested it. When I press the button in LoveLace it works, but not by activate script by voice.
Do I need to install a module in Node-Red?
You have to expose the script to Google Assistant. I did it via Home Assistant Cloud, as I mentioned here.
