hi, i want to start with home control and HA cloud
but what languages are now supported for HA? is it limited to EN only? because now lost of languages are supported… is there documentation availble for this?
as far as I know the language is set on your GA, not in HA, but you’ll need to name your entities in a way that GA can understand
ah ok, but for example, now logitech harmony, also have full home control mode now in GA
but only supported to ENG languages
so i thought , its up to HA cloud to support more languages
second question, if its not possible, can you we try alternative languages with the older NON cloud GA component?
I have 2 languages set on m GA for my Google Home Minis
I can say the command in either language but I have to make sure I say it right at times (my entities are all named in English so I sometimes have to adjust how I say things in French so that GA understands)
ok cool, seems GA is smart enough to translate it then
can you alsos setup feedback commands
you say : hey google turn on lights
google home (mini) says feedback : ok turning light on
do you hear that feedback ?
that’s a default standard feature
cool, but i remember i tested the GA component (not cloud version), then you needed to configure the TTS commands, but it wasnt working without a valid SSL certificate
i think its maybe different with the cloud version then ?
I’m not using the cloud. You don’t need to set TTS, if the connection is set correctly and the action received and understood (by GA first and then by HA) you’ll get audio feedback on your GH to confirm the action was successful
ok, thnx, gonna test it out
