Just upgraded to the latest version of Core and OS on my Pi. I put in the HTTP config before and I can remotely access the UI, however Google Assistant can no longer login and I get this notification:
Login attempt failed
Login attempt or request with invalid authentication from rate-limited-proxy-108-177-64-205.google.com (108.177.64.205). See the log for details.
I don’t know where the log this notification speaks of resides, so I haven’t been able to check it.
Here is my YAML for the HTTP:
http:
server_port: 8123
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- 192.168.1.2 #This is my NGINX reverse proxy server
ip_ban_enabled: false
login_attempts_threshold: 100
Can anyone point me in the right direction to get it going again?
