Hi, every one!! I have a problem with Google Assistant integration for Home Assistant Cloud, I configurated it and expose my scripts in order to do action with my ligths devices. But I can see an error in sync process.
The error when I clic in PRESS button is > Failed to call service button/press. Unable to sync devices with result code: 404, check log for more info.
Error Log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:239
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 22:13:51 (7 occurrences)
Last logged: 22:33:28
[139759812644160] Unable to sync devices with result code: 404, check log for more info.
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 239, in handle_call_service response = await hass.services.async_call( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/core.py”, line 2543, in async_call response_data = await coro ^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/core.py”, line 2580, in _execute_service return await target(service_call) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 971, in entity_service_call single_response = await _handle_entity_call( ^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1043, in _handle_entity_call result = await task ^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/components/button/init.py”, line 138, in _async_press_action await self.async_press() File “/usr/src/homeassistant/homeassistant/components/google_assistant/button.py”, line 60, in async_press raise HomeAssistantError( homeassistant.exceptions.HomeAssistantError: Unable to sync devices with result code: 404, check log for more info.
Could you help me please
thanks
