I found I had to restart the Matter-Hub addon, then right after that pair with Alexa (looked to me like the hub stops listening for new connections after a while…)
I do not use IPv6 on my home assistant network. However, I have a dozen Matter devices already working fine directly with the home-assistant Matter integration over IPv4. For example light bulbs.
My goal is to control my other Alexa devices from home assistant. For example, being able to tell Alexa to control various devices in home assistant.
I read the docs and I interpreted IPv6 as recommended and not required. Moreover, it reads as required for Docker based install and I do not have HASS in a docker. My HASS is bare-metal on x86.
I think Ive had some success…not sure what Ive done and im too scared to try again because this is not my working instance. The only thing I did different was to scan the code after I stopped and restarted the hub. The only issue I see though is all my devices are showing as offline in google home…any ideas? Phil?
If i sync all devices some come online but when i switch one on it goes straight to offline again.
Quick question can you start fresh i.e. no devices in google home and then bridge it with matter hub? because Ive tried again and again its saying i need a hub for it to work? Reason why i did it this way is because my devices were offline
By no means an expert on this, however I thought you needed at least one Google Home comparable device (Hub, Speaker or WiFi) to act as a Matter Bridge inside your network…
Thats likely correct, however my system connected several times now and that shouldnt be possible based on that assumption?
In saying that i cannot connect again, im trying to find out why sometimes it connects and othertime it doesnt.
I will see if i can buy a google home hub see if it makes a difference.
If this works its a better solution
Thanks Phil…your were spot on, installed a cheap google hub and away it went. Thanks so much for helping me out.
Quick question once the QR code is commissioned thats it yeah? no more changes can be made like including or removing devices? without adding a new or factory reset the code?
You can add and remove new devices to a hub at any time. You just need to restart the addon after they have been added and they will then show up in a Google/Alexa, no need to go through the commissioning process again. (I have done this a bunch of times without issue)
