Google Assistant no more available
Hi all,
after the update of HA and GA app on my android phone I’m no more able to link them using home control.
If I click on test app I can see the welcome page where user and password are required. But then when the syncro starts nothing happens.
Can someone please support me?
thank you in advance
I had the same issue yesterday, with the new Google app… I unlinked, then went to the Google actions site, created a new draft version with simulator, then I was able to link again … I also had to delete the authentication token for Google in my ha user profile, otherwise I was stuck after entering user and password when I was linking the test app
i tried but no changes.
Can you please be more specific?
Maybe I’m missing some step
I have this problem too
Which version of HA? The behaviour changed in 0.83 and reverted back in 0.84
with 0.83 work well
after update to 0.84 doesn’t work
if I restore 0.83 work again
so if you added:
expose_by_default: false
in version 0.83 then you need to remove that in 0.84. This is the same as the pre-v0.83 config for google assistant. They reverted the change they made in 0.83 for 0.84
How do you guys now that? I don’t see those changes on release notes pages…
a very stranger thing is that now I can’t see any account connected and I don’t see any device on my Google Home app… but… Google Assistant accept voice commands to turn on/off lights or other… buuuut… with an Actions Project that I have deleted o.O
google… what’s your problem?!
That’s an issue with Google, called: ghost devices
but Home still not working :smiley:
ok… assistant work… home not!
I don’t think that is a Google bug because as I say before with 0.83 all work fine
after 0.84 update home stop work, rollback to 0.83 home work again
so… this is a 0.84 problem
I have also problems after upgrade to Home Assistant 0.84.2.
I don’t see my components any more in google home app, the only thing that I could see are my lights.
There was no problem with an early version of Home Assistant.
@DavidFW1960 where do I need to set this option: expose_by_default: false
I have also an error message when I do: google_assistant.request_sync
request_sync request failed: 404 b’{\n “error”: {\n “code”: 404,\n “message”: “Requested entity was not found.”,\n “status”: “NOT_FOUND”\n }\n}\n’
I checked my ID plus key and these ones are correct.
Hopefully somebody could help us with this issue google home and home assistant.
Regards,
Michel
I remove all this from configuration.yaml
  exposed_domains:
    - SWITCH
    - LIGHT
    - CLIMATE
  entity_config:
    group.all_automations:
      expose: false
    group.all_lights:
      expose: false
    group.all_switches:
      expose: false
and work!
only left
google_assistant:
  project_id: my-id
  api_key: my-key
@itmax86 you are the men, SUPER that works also for me :slightly_smiling_face:
ok the problem is only
 exposed_domains:
this work
entity_config:
the problem now is that HA expose the room group… and I don’t need that :smiley:
EDIT:
ok… the solution…
I add
group.room:
  expose: false
for every room I have and that disappear from G Home
thank you! It worked!
I got all confused about something working, then not working, then applying a fix, remove it, put it back, change, standing back flip and… now i am totally lost.
Which is the correct configuration to expose to Google Assistant/Home, only SOME entity_id in 0.84 (and hopefully also for future versions)
use this
google_assistant:
  project_id: your_id
  api_key: your_key
  entity_config:                  #configure single entity
      expose: false
I don’t understand, why you have to put group.all_automations there if you put expose false. I would assume that you put ONLY all the entity_id that you want to be EXPOSED not the other way or am I missing the logic?
