Hi there,
I have installed the Google Assistant Add-on to my Hass.io. I have setup my config file as such:
"mic": "1,0",
"speaker": "0,0",
"client_secrets": "google_assistant.json"
My microphone is working correctly but audio is not playing though the speakers I have plugged into the headphone jack. If I have my TV turned on, which is connected to the Raspberry pi, I get audio through that. This does not make sense to me since these are my logs showing the HDMI is on “0,1”, not “0,0”.
[Info] Show audio device
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
[Info] Setup audio device
[Info] Install/Update service client_secrets file
Has anyone had this problem before? Is my headphone jack located at a different location?
