Google assistant not seeing entity_config
I connected Google Home to HA through the manual setup. I add the devices I want to expose through the entity_config option (expose_by_default is off). Now I’m having the problem that new entities I expose this way are not added to Google Assistant when I sync. Only the entities that I added when I first set up this integration are shown. When I change expose_by_default from false to true all (supported) entities are added to Google Home, but when I change it back to false all devices are removed except the one that where added when I did the initial setup.
Has anyone seen this behavior before, and if so do you know a solution?
