Today I decided to add Google Assistant integration, all but one things seems to work fine. I am under the impression that the room attribute of for example a light will put the device automatically in a room that can be found in the Google Home app but I cant seem to get it working. Here my config:
As you can see I specified Leefkamer as a room. When the room wasn’t created automatically I created it manually but that didn’t help. Here are some screenshots:
It shows my ‘Leefkamer’ (which is a group of lights created by Deconz zigbee integration) under the list of ‘Linked to you. 24 devices not I a home’. Am I doing something wrong? Why isn’t the entity getting added to my Leefkamer room. Note that I asked google to sync me devices and that it succesfuly did so. I also refreshed in the Google Home app by swiping down.
Update: I have the same issue when using nabu casa
I did by saying hey Google sync my devices. But does this also refreshes things on my Google home app? Update: removed the alias and it still wasn’t assigned to a room automatically
I found the issue: I have 2 homes configured in my Google Home app and this caused it to NOT work, I removed the other home, resynced and it added my device to the correct room.
I also face this problem, as my wife was unable to use a script synced by me to GH, as I could not move it to our common home.
I ended up solving it like this:
create a helper of type input_boolean (which is visible in Google Home /as switch/, thus can be moved among homes and rooms, thus can be controlled by other members of the home it ends up assigned in)
using the switch as trigger for a HA automation, which then run the desired script
