For the last few days, I have noticed that Google Assistant cannot control my devices and occasionally neither can using a browser, usually only my Tradfri lights.
I have tried rebooting hassbian, using 82.0 I have not changed anything that I can see. I used the Nabu Casa system to integrate it, paying the fee.
Log shows nothing but here is what it is saying now
2018-11-11 15:19:52 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2018-11-11 15:22:46 WARNING (MainThread) [homeassistant.components.cloud.iot] Connection closed: Invalid auth.
2018-11-11 15:30:36 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x67c110d0>, 'Connect timed out. (connect timeout=5.0)')': /bot788630633:AAF6CQOw0t4r9wAOxZn6XeEK-jVbGpnRBzA/getUpdates
2018-11-11 15:36:33 ERROR (MainThread) [homeassistant.core] Error doing job: Fatal read error on socket transport
File "/usr/lib/python3.5/asyncio/selector_events.py", line 723, in _read_ready
data = self._sock.recv(self.max_size)
OSError: [Errno 113] No route to host
2018-11-11 16:00:35 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x67c110d0>, 'Connect timed out. (connect timeout=5.0)')': /bot788630633:AAF6CQOw0t4r9wAOxZn6XeEK-jVbGpnRBzA/getUpdates
2018-11-11 16:20:18 ERROR (MainThread) [homeassistant.components.updater] Got unexpected response: None
2018-11-11 16:30:31 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x67c110d0>, 'Connect timed out. (connect timeout=5.0)')': /bot788630633:AAF6CQOw0t4r9wAOxZn6XeEK-jVbGpnRBzA/getUpdates
2018-11-11 17:30:33 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x67c110d0>, 'Connect timed out. (connect timeout=5.0)')': /bot788630633:AAF6CQOw0t4r9wAOxZn6XeEK-jVbGpnRBzA/getUpdates
2018-11-11 18:02:04 ERROR (Thread-12) [homeassistant.components.recorder.util] Error executing query: (sqlite3.OperationalError) database is locked (Background on this error at: http://sqlalche.me/e/e3q8)
2018-11-11 18:07:15 ERROR (MainThread) [aiohttp.access] Error in logging
File "aiohttp\_helpers.pyx", line 24, in aiohttp._helpers.reify.__get__
KeyError: 'remote'
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/helpers.py", line 462, in log
for key, value in fmt_info:
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/helpers.py", line 454, in <genexpr>
for key, method in self._methods)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/helpers.py", line 412, in _format_a
ip = request.remote
File "aiohttp\_helpers.pyx", line 32, in aiohttp._helpers.reify.__get__
File "aiohttp\_helpers.pyx", line 26, in aiohttp._helpers.reify.__get__
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_request.py", line 343, in remote
peername = self.transport.get_extra_info('peername')
File "/usr/lib/python3.5/asyncio/sslproto.py", line 306, in get_extra_info
return self._ssl_protocol._get_extra_info(name, default)
File "/usr/lib/python3.5/asyncio/sslproto.py", line 546, in _get_extra_info
return self._transport.get_extra_info(name, default)
AttributeError: 'NoneType' object has no attribute 'get_extra_info'
Really getting annoyed at this stage as I removed Smartthings from my setup
