Google Assistant SDK commands very delayed?
Do you also find the commands to be very delayed?
If I write a command in english then I get the green tick after about 4-5 seconds, it doesn’t work but it responds fairly fast.
But if I write the command in swedish then it works but it takes 12-15 seconds to get the green tick and a successful command.
I asked to get a Zigbee light turned on, so it shouldn’t be the light that takes time, and usually it responds instantly.
Is this normal?
Yes it’s normal. The delay is on Google’s end. You can see the server latency at https://console.cloud.google.com/apis/api/embeddedassistant.googleapis.com/metrics
