Google Assistant SDK error 401
How to start over. I deleted in Google because of an authorized error. So I thought about starting over. But the integration sends me straight to the page that tells me: Nothing to find in the docker directory. So how to start the process again
The OAuth client was deleted.
If you are a developer of this app, see error details.
Error 401: deleted_client
Got it I needed to get rid of the authorization.
  • settings
  • the … (dots) in right upper corner.
  • Application Credentials
  • Select and remove selected
Could it be that you already have application credentials (that are deleted or no longer valid) for google set in your home assistant? You can check this by going to settings → devices and integrations → click on the 3 dots (upper right corner) and select application credentials. there you can see if you already have credentials set. If so try to delete them. next try again to ‘add integration’ you should now be able to entre your (valid) credentials again
Thank you. That is exactly what I needed to know!!
you make me the day
