I am running home assistant on Rpi3. I am using zigbee2mqtt and node red for most of my applications.
For example, pressing a zigbee switch, node red processing and the final action takes place under half a second usually.
However once I have added google_assistant integration all response slowed down considerably.
When I press the button, lights turn on/off in about 4-5 seconds.
I have found out that setting
report_state: false
resolves that problem.
Is there some synchronous communication happening to google assistant that is slowing things down.
Anyone else experienced something similar?
The lights I am switching are exposed to google assistant.
Any suggestions on how to keep the state reporting while having somewhat reasonable responses?
