When reading: Google Assistant - Home Assistant
It shows that temperature sensors should be visible in google home app (and they’re) only thing is they’re not showing temperature. Also the vacuum domain isn’t working. Is there anything I have to do to make google understand HA? Lights are working fine.
Upgrade to 95.4, some issues on earlier release…
Try to unlink and link again the services, then you know you know you have a good sync…
Or with the command : sync my devices…
Thanks. so it only works in the beta currently? All my devices are synced successfully and even did a unlink and link with no success. How do I operate the vacuum ? Thanks about the temperature sensors. Indeed you should ask Google what it is. It doesn’t display it …
