Google Assistant Trait Suggestions
Just recently I have updated the google_assistant/trait.py code to handle some specific and common vacuum commands (mine being the roborock S6) to support Locator, StartStop (zones) and EnergyStorage. With these traits being added/modified I am now able to query the battery level, clean by zone/segments and locate my vacuum cleaner which pretty much surpasses even the Xiaomi Home app yet very simple to integrate.
Furrther more, I found overriding the google_assistant/trait.py file to be bad practice as this can be prone to problems in future updates etc. So could it be viable to have some kind of way where the integration checks to see if another integration has an override trait? Simply put, this could be a simple check to see if an integration has a method for a certain trait in which it can call instead of resorting to the default. I say this because I know you can already add traits with @register_trait which is fine but for a trait already defined like StartStopTrait would create the same trait twice if an integration wanted to have its own customized version of StartStopTrait. Maybe even just removing duplicates in the GoogleEntity _traits list?
I understand the universibility behind a constant set of traits but limits those integrations that has extra features from its full potential when it comes to Google Assistant and the commands it could give.
Below is my added traits which should be self explainatory but would like the moderators/coders of google_assistant to consider adding these for additional functionality into the Google Assistant eco.
TRAIT_LOCATOR = f"{PREFIX_TRAITS}Locator"
TRAIT_ENERGY_STORAGE = f"{PREFIX_TRAITS}EnergyStorage"
COMMAND_LOCATE = f"{PREFIX_COMMANDS}Locate"
COMMAND_CHARGE = f"{PREFIX_COMMANDS}Charge"
@register_trait
class VacuumEnergyStorageTrait(_Trait):
    name = TRAIT_ENERGY_STORAGE
    commands = [COMMAND_CHARGE]
    @staticmethod
    def supported(domain, features, device_class):
        if domain == vacuum.DOMAIN:
            return features & vacuum.SUPPORT_BATTERY
        return False
    def sync_attributes(self):
        return {
            "isRechargeable": False,
            "queryOnlyEnergyStorage": True
    def query_attributes(self):
        attrs = self.state.attributes
        return {
            'capacityRemaining': [{
                "rawValue": attrs.get('battery_level'),
                "unit": "PERCENTAGE"
            'isCharging': attrs.get('status') == 'Charging',
            'isPluggedIn': self.state.state == vacuum.STATE_DOCKED
    async def execute(self, command, data, params, challenge):
        _LOGGER.error('Command Charge Executed: %s', command)
@register_trait
class VacuumFanSpeedTrait(_Trait):
    name = TRAIT_FANSPEED
    commands = [COMMAND_FANSPEED]
    @staticmethod
            return features & vacuum.SUPPORT_FAN_SPEED
        return False
        speeds = []
        modes = self.state.attributes.get(vacuum.ATTR_FAN_SPEED_LIST, [])
        for mode in modes:
            speed = {
                "speed_name": mode,
                "speed_values": [{"speed_synonym": [mode], "lang": "en"}],
            speeds.append(speed)
        return {
            "availableFanSpeeds": {"speeds": speeds, "ordered": True},
            "reversible": False,
        speed = self.state.attributes.get(vacuum.ATTR_FAN_SPEED)
        response = {}
        if speed is not None:
            response["currentFanSpeedSetting"] = speed
        return response
        domain = self.state.domain
            await self.hass.services.async_call(
                vacuum.DOMAIN,
                vacuum.SERVICE_SET_FAN_SPEED,
                    ATTR_ENTITY_ID: self.state.entity_id,
                    vacuum.ATTR_FAN_SPEED: params["fanSpeed"],
                blocking=True,
                context=data.context,
@register_trait
class VacuumLocatorTrait(_Trait):
    name = TRAIT_LOCATOR
    commands = [COMMAND_LOCATE]
    @staticmethod
            return features & vacuum.SUPPORT_LOCATE
        return False
        return {}
        return {}
            vacuum.DOMAIN,
            vacuum.SERVICE_LOCATE,
            {ATTR_ENTITY_ID: self.state.entity_id},
            blocking=True,
Additionally I modified the StartStopTrait to support zone cleaning with the vacuum. I’ve created another post in hopes that the Vacuum Entity will support zones so that this can be integrated in the future and allow zone cleaning through Google Assistant natively. https://community.home-assistant.io/t/vacuum-entity-to-support-zones/259904
VACUUM_ROOMS = {
    'hallway': 21,
    'family room': 27,
    'living room': 26,
    'bathroom': 19,
    'toilet': 18,
    'kitchen': 16,
    'study': 17,
    'master bedroom': 24,
    'kids bedroom': 20,
    'laundry': 23,
    'entrance': 25
    @staticmethod
        """Test if state is supported."""
            return True
        if domain == cover.DOMAIN and features & cover.SUPPORT_STOP:
            return True
        return False
        """Return StartStop attributes for a sync request."""
            return {
                "pausable": self.state.attributes.get(ATTR_SUPPORTED_FEATURES, 0) & vacuum.SUPPORT_PAUSE != 0,
                "availableZones": list(VACUUM_ROOMS.keys())
        if domain == cover.DOMAIN:
            return {}
        """Return StartStop query attributes."""
        state = self.state.state
            return {
                "isRunning": state == vacuum.STATE_CLEANING,
                "isPaused": state == vacuum.STATE_PAUSED,
            return {"isRunning": state in (cover.STATE_CLOSING, cover.STATE_OPENING)}
        """Execute a StartStop command."""
            return await self._execute_vacuum(command, data, params, challenge)
            return await self._execute_cover(command, data, params, challenge)
    async def _execute_vacuum(self, command, data, params, challenge):
        if command == COMMAND_STARTSTOP:
            if params["start"]:
                if "zone" in params or "multipleZones" in params:
                    zones = []
                    if "multipleZones" in params:
                        for zone in params["multipleZones"]:
                            zones.append( VACUUM_ROOMS.get(zone) )
                    else:
                        zones.append( VACUUM_ROOMS.get(params["zone"]) )
                        'xiaomi_miio',
                        'vacuum_clean_segment',
                            'segments': zones
                        blocking=True,
                else:
                        self.state.domain,
                        vacuum.SERVICE_START,
                        blocking=True,
            else:
                    self.state.domain,
                    vacuum.SERVICE_STOP,
                    blocking=True,
        elif command == COMMAND_PAUSEUNPAUSE:
            if params["pause"]:
                    self.state.domain,
                    vacuum.SERVICE_PAUSE,
                    blocking=True,
            else:
                    self.state.domain,
                    blocking=True,
    async def _execute_cover(self, command, data, params, challenge):
            if params["start"] is False:
                if self.state.state in (cover.STATE_CLOSING, cover.STATE_OPENING):
                        self.state.domain,
                        cover.SERVICE_STOP_COVER,
                        blocking=True,
                else:
                    raise SmartHomeError(
                        ERR_ALREADY_STOPPED, "Cover is already stopped"
            else:
                    ERR_NOT_SUPPORTED, "Starting a cover is not supported"
        else:
                ERR_NOT_SUPPORTED, f"Command {command} is not supported"
