I finally set up the Google assistant integration for Home Assistant.
At the moment every device is working with vocal commands but 3 out of 46 devices have a problem.
Whent I try to turn ON or OFF one of those 3 devices through Google Assistant it says “an unknown error occurred with […]” but the device turns OFF and ON with no real problems.
It doesn’t seem to be a specific problem with the type/brand of those devices (SONOFF and Tuya zigbee 2 gang switches) since the exact same types of devices are working fine and they are very clos to each other.
Is there a way to fix this issue?
Thank you in advance
