I have Google Assistant configured (without Nabu Casa).
From today he started acting in his own way. Sometimes when you open the Home app, the entities are unavailable, and sometimes they are working. An attempt to synchronize from the Home assistant level results in the following information in the log.
2024-10-02 22:36:02.373 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 500
2024-10-02 22:36:02.374 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547331636192] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2761, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2804, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 996, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1068, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/button/__init__.py", line 132, in _async_press_action
await self.async_press()
File "/usr/src/homeassistant/homeassistant/components/google_assistant/button.py", line 60, in async_press
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Unable to sync devices with result code: 500, check log for more info.
I tried to create a new project and configure everything again, but it did not solve the problem. Anyone have a similar problem?
EDIT: problem solved. To access homeassistant, I use the cloudflared and agro tunnel add-ons. Connection attempts were blocked by the cloudflare WAF firewall.
