I was just curious if anyone knows how to troubleshoot this issue. I have configured the google assistant integration, as well as device sync for home assistant according to the documentation in the HA wiki. I use an nginx reverse proxy to expose HA to the internet with an SSL certificate. Sometimes (about 20% of the time) when I issue a command to my google home device like “turn off the bedroom TV”, it will perform the action successfully (bedroom TV will turn off) but then the google home will say, sorry I couldn’t reach my test app.
I have looked on the google actions console for any sort of logging I can find that would help me better narrow down the problem, but I cannot seem to find any logging from voice commands to HA.
Any help in narrowing this down would be greatly appreciated.
Hi, I have the same issue. Google assistant integration works fine, but sometimes after a command GA says “sorry, cannot reach app”.
I do not have a reverse proxy. Any clues will be appreciated.
I have the same issue. Worked at first but no more.
THIS IS A WARNING on the HA forum
To use Google Assistant, your Home Assistant configuration has to be externally accessible with a hostname and SSL certificate. If you haven’t already configured that, you should do so before continuing. If you make DNS changes to accomplish this, please ensure you have allowed up to the full 48 hours for DNS changes to propagate, otherwise Google may not be able to reach your server.
I don´t get it. Can someone please explain where can we allow 48 hours for dns changes to propagate? Thanks in advance
I find that mine was still hit or miss - it’d work about 50% of the time… Usually failing the first time, but working on a second try…
After a while, its just not worth doing anymore - so I replaced it with a few IFTTT commands… Not as good, but it works 95% of the time instead of being hit or miss…
How would one go about doing this if I have scenes that take too long? Would I make the Google Assistant config ignore scenes, and then make switches for them?
This last method seems to do the trick. I believe the script is exiting instantly, and thus functioning. The only problem I have left is “turn off all lights” is reserved within Google Assistant, so I can’t assign an action to that phrase and since some lights are unavailable, the return time is too slow.
I think the only way to fix that is if an option was added to the Google Configuration to allow for “instant return” without waiting for a status.
This may not be the OP’s issue, but if anyone else experiences Google Assistant intermittently replying, “Sorry, I can’t reach the [home assistant] right now”: I strongly recommend enabling local fulfillment for Google Assistant. This will substantially lower the fulfillment failure rates especially if you are using DuckDNS for your remote HA access. As a bonus, the fulfillment latency will also decrease. The default is cloud fulfillment - Google Assistant accessing HA via your dynamic DNS solution.
