I added a new devices to my z-wave stick and tried to sync it to google assistant but get a error respons that something went wrong. In the log i get this error messange - any idea?
Connection closed
File "/usr/src/homeassistant/homeassistant/components/google_assistant/__init__.py", line 92, in request_sync_service_handler
res.raise_for_status()
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 942, in raise_for_status
headers=self.headers)
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request'
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 130, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
await handler.func(service_call)
File "/usr/src/homeassistant/homeassistant/components/google_assistant/__init__.py", line 94, in request_sync_service_handler
body = await res.read()
File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 969, in read
self._body = await self.content.read()
File "/usr/local/lib/python3.7/site-packages/aiohttp/streams.py", line 335, in read
raise self._exception
aiohttp.client_exceptions.ClientConnectionError: Connection closed
I guess you’re not using nabucasa cloud.
Please check documentation here :
Mainly this :
Syncing may also fail after a period of time, likely around 30 days, due to the fact that your Actions on Google app is technically in testing mode and has never been published. Eventually, it seems that the test expires. Control of devices will continue to work but syncing may not. If you say “Ok Google, sync my devices” and get the response “Unable to sync Home Assistant”, this can usually be resolved by going back to your test app in the Actions on Google console and clicking Simulator under TEST . Regenerate the draft version Test App and try asking Google to sync your devices again.
I tried this but the app was in “TEST MODE”. Tried to reload/change version but then i get a error messange. See picture below .
After the error message i get the option to test app but then i do that i get the same error. But when i reload the the page my app is back in testning mode.
Do i have to unlink my app from my google home app before I can reload my app?
So far as I know the google issue has been fixed a couple of days ago.
I have changed my domain, edited my domain name in 3 places in Google Actions Console, unlinked the app, relinked the app and everything is working fine.
I don’t see any current issues.
Not so far as I know.
Yesterday I edited the domain name and didn’t touch the linking in the app and it worked. I did unlink/relink after that but I don’t think that was necessary.
In setup>account linking> 2 places…
Authorization URL https://domain:port/auth/authorize (port only if you don’t use 443
Token URL https://domain:port/auth/token
actions> 1 place
Fulfillment URL https://domain:port/api/google_assistant
This is very interesting. I had this issue where I could not sync my devices anymore even with creating a new draft. Just now I read your recommendation and simply reviewed my URL’s. I dont use port 443 for SSL so my URL’s were correct per your examples. Then under the action part I simply just hit enter and it saved the draft and generated a new preview. Did not need to link accounts or anything and syncing just worked after that! So it seems we need to regenerate something, even if nothing is changed.
