Hi all,
I have gone through the setup of google calender but I seem to be stuck in a little loop.
I have added the configuration entries, and restarted, to which then I see a notification prompting to proceed to authorisation with a code…
-as such…
“In order to authorize Home-Assistant to view your calendars you must visit: Sign in - Google Accounts and enter code: XXXX-XXXX”
I do this, and all seems to be fine with the google auth.
When I restart home assistant I see the same notification prompting to proceed to google to complete authorisation as previously done…and so on.
Has anyone else encountered, and overcome this?
