If you have a more complex automation triggered by something other than the calendar event, you can make a template binary sensor from the event triggers. This is an example searching for an event with a specific name:
This is a bit beyond my level of understanding.
Would the following do, meaning to start 45 before sunset on the evening before the calendar (Nellie) and ending 25 hours later, around sunset on the day of the calendar (Nellie) ?
alias: Test Yurzeit
description: ‘’
SORRY… I made a mistake
alias: Test Nellie
description: ‘’
The example I have above creates a template binary sensor (Template - Home Assistant) that you can use in other automations combined with other conditions.
I’m having trouble understanding what you’re trying to accomplish.
