I’m trying to use a google calendar for triggering an automation for increasing the heat in our cabin prior arrival. I have a calendar that says “Booked” in the calendar event when someone has planned to use our cabin. What I would like to do is to have an automation that triggers if there is such an event within the next 48 hours and then increase the heat.
I’ve had a look through that and as far as I can tell this will only work if the action is to be carried out on the same day as the event. What I’m trying to do is have a switch turn on 26hours before an event if that’s possible.
