Not a valid origin for the client: http://192.168.1.13:5050 has not been whitelisted for client ID 951565782741-xxxxx.apps.googleusercontent.com. Please go to https://console.developers.google.com/ and whitelist this origin for your project's client ID."
Is what I get for the error in the console. My config is as follows,
I get that, but HADashboard is going to load the internal IP, unless I port forward my internet to :5050, and then use my ddns host, but I dont want HADashboard internet facing. So bit stuck, and wondering how @WazWaz managed to do it.
no you dont need to portforward 5050.
you can use a proxyserver that connects an outside dns to your proxyserver (with port 433 like ha uses)
and redirect it to 5050.
but i dont think you can use google api without opening up to the net.
other option is to install a local dns server to create a local name for your dashboard.
i hope for you that he hasnt opened his dashboard up to the net.
So messed around a bit more and added in my ddns host to the google api, just added the host, not port forwarded anything, and now I get a different error, and I can click on the authorise button, but still brings up an 400 error.
i did some reading on xip.io
but to get that to work you need to edit your local dns and add http://192.168.1.13.xip.io:5050 somewhere so that you can use that in your browser.
the xip.io site itselve is down, so i cant read up there, and i cant find out how to use xip.io
You are a superstar @ReneTode So I added this line to my HOSTS file on windows in the Windows/System32/Drivers/etc folder,
192.168.1.13 192.168.1.13.xip.io
and it now lets me authorise it, and it works, but obviously now I have to use the address, http://192.168.1.13.xip.io:5050 to access HADashboard, and I can easily edit my host file on my windows PC, but on my iPad, which is where I will mainly be using HADashboard, I can’t edit host files, so I am kinda still back at square one
I tried going back to just http://192.168.1.13:5050 after authorising it, but it went back to the please login page.
i think it needs to be installed on the device that you run d on and then activated.
from that moment on you should be able to use the xip.io on every device in your system.
but i cant find much documentation about it.
i think you need to google a bit more about xip.io (usage, install, doc, example, etc)
I like the concept @WazWaz has come up with, its exactly what I would be after. But unfortunately I am not a coder, I can hack together other peoples code, and change around to my preference, but thats as far as my skills go unfortunately
Like the look of it, shame I can’t get it work without the .xip.io bit, and it seems to bleed into the control panel as well, but we are getting somewhere
Sorry, I wasn’t clear - you also have to open the page via the http://192.168.1.13.xip.io:5050 too (i.e. open your dashboard in your browser). Alternatively, if your router serves DNS (usually as a “home” domain), you can use http://hassio.home:5050, and add that to the permitted domains.
Ideally, everyone would be honest and we could all just use one public APIKEY etc., and there would be no setup required. Tragedy of the commons.
Probably another thing this HASS.IO Cloud could help with - have an account on HASS.IO cloud and get keys from there. If it gets abused, we change the keys.
As above, thats fine on something I can redirect my host on, but on my ipad, which is what I am setting all this up for I can’t do it, I guess I might be able to setup a redirect in router. Just waiting for a new one to be delivered hopefully, then I am going to re-setup my network.
Invalid Redirect: http://hassbian.home:5050 must end with a public top-level domain
Is what I get when I try and add in my host. Close, but no cigar
I guess as their website is down, that maybe their DNS is down too, as it doesn’t work on my ipad currently, and only way to get it to work on the PC was to edit the host’s file, which wasn’t ideal.
I needed to change my DNS setting on my LAN to an internet DNS server first, so changed it to 4.2.2.2 and then my secondary DNS to my routers IP, and then it resolved 192.168.1.13.xip.io to 192.168.1.13. And on the iPad, changed the DNS to manual and set the server to 4.2.2.2 and that again caused 192.168.1.13.xip.io to work. Yay, finally got there.
I couldn’t find any way to make it work automatically, you’ll just have to change the “400px” in the .css file manually. I’m no css wizard, as you can see.
