Google calendar event config not finishing
I’m trying to set up the google calendar event config according to
https://home-assistant.io/components/calendar.google/
The stuff with the google API console worked out, also the oAuth request after the first boot to allow HA access to the calendars.
However, the google_calendars.yaml file was not created automatically and nothing else popped up in the HA UI.
I would have expected to see the file containing one calendar (the default one).
Is this a bug?
Jochen
I have the same problem.
Does anyone know how to solve this?
Ever get an answer on this? I’ve had the same issue pop up
