I’m trying to set up a reminder using the Google Calendar event integration. I’ve got it to working, but the documentation (https://www.home-assistant.io/integrations/calendar.google/) says that message will have the search values extracted and that is not what I’m seeing.
Hi @Didgeridrew. Did you get to the bottom of this? I’m seeing the same issue where the search term still remains in the message and is not removed despite what the documentation states.
After a little trial and error, I found that you don’t have to put the search term in the heading/message of the event; you can put it in the notes section of the event and it will still be sorted into the correct calendar in Home Assistant.
