Google Calendar Event NOT WORKING
Hi
i follow this guide step by step
but somethig go wrong
everytime hi restare there is a message that invite me to inserte a code
in this google page
In order to authorize Home-Assistant to view your calendars you must visit: https://www.google.com/device and enter code:XXXXXXXXX
i dont have any sensor available
only an Entity called google calendar notification that show this error
Google Calendar Setup
message
In order to authorize Home-Assistant to view your calendars you must visit: https://www.google.com/device and enter code: XXXXXXX
i already entered the code 10s times at every restart.
There isn’t any file google_calendars.yaml in my config directory
i created one and put this inside:
- cal_id: "*****@group.calendar.google.com"
  entities:
  - device_id: HA_Google_Calendar
    track: true
  entities:
  - device_id: test_important
    track: true
    search: "#Important"
    offset: "!!"
  - device_id: test_unimportant
    track: true
    search: "#UnImportant"
I have also calendar.ljmerzagmailcom installed but i have error 404
Any idea about what could be went wrong!
Very Thanks!
HA logs is full of this error
syncworker outh2client.client Failed to retrive access token
error invalid client unauthorized
