Hello! I’m really stuck here after trying for several days and combing through the forums. I’m trying to turn the lights off (the scene in the yaml does this and works fine when triggered manually) at the beginning of a Google Event but for some reason it triggers at the end instead of the beginning. I’m having trouble understanding why this is the case. Here’s the yaml for the automation:
alias: Calendar - 💤 Sleep
description: ""
- platform: calendar
event: start
offset: "-0:0:0"
entity_id: calendar.xxx_gmail_com
condition:
- condition: state
attribute: message
state: 💤 Sleep
for:
hours: 0
minutes: 0
seconds: 0
- service: scene.turn_on
entity_id: scene.all_off
metadata: {}
mode: parallel
max: 10
In case it’s important my version of HA is 2023.2.5
I really appreciate any help or suggestions anyone might have. Thank you!
Edit: I forgot to mention that my calendar is back to back events almost all the time (though not all of them are meant to be triggers). I think I read somewhere that that might pose a problem, but I’m having trouble finding the post that said that again so I can try to understand why and maybe come up with a solution.
