Hi, I am just starting to setup the Google Calendar component. Can we have multiple calendars coming from different Google Accounts? Right now I am setting up the family calendar, but was hoping to get another calendar that would take care system events etc, that I don’t want to clutter the family calendar with.
I searched the board and haven’t seen such a setup. If this is possible, what my configuration.yaml look like in order to identify both calendars.
You can have multiple calendars, as long as they are shared with the account you’re using. By default when you start Home Assistant it’ll check for new calendars.
So if I understand this correctly, I can have multiple calendars, but only from one account. But not from two different Google mail accounts. Humm that will put a damper in my plans, I wanted to keep things separate as not to clog the family calendar.
You use [email protected] for your sensor in the HA, then go to your Google accounts for the other 2,share the calenders with [email protected], restart HA, taa-daa, 3 calendars.
i have this working, i shared my calendar with the “master” account in homeassistant , so in the sensor itself on the home page, i see my events, i also see the new calendar in cal event yaml file
my calendar is shared with full permission, so all looks fine
but when i want to show to show my calendar in an IFRAME, it gives an error
Events from one or more calendars could not be shown here because you do not have the permission to view them.
unless i make it public, it works, but that something i dont want offcourse
so why is iframe not working, and sensors is working ?
Blockquote
Hi i did has you sad, i shared my wife calendar to my’n,
i can see my wife event on my googe calendar, but i dont see it in my calendar tub in HA ?
OK thanks. i restart HA and the shared google calendar came up.
so now i see in my “google calendar card” in HA my and my wife calendar.
is there a way to differentiate between my event on the calendar and my wife event in
any way?
Nevermind, I’ve fixed it. I edited my google_calendar.yaml file to show the ID, now it’s listed in my states and I could use that to display the calendar events on there Thanks
