Google Calendar integration: Can't add new entity to calendar
I have successfully set up the google calendar integration following the description given here:
But when I try to add a new entity to one of my calendars or change an entity (add a name, for example), this duplicates the old entry for the calendar and the new entity is not present in under the Developer Tools->States page.
For example:
I have this (automatically generated) entry in google_calendars.yaml:
- cal_id: [email protected]
  entities:
  - device_id: private
    ignore_availability: true
    track: true
This device works and it’s present as calendar.private on the States page.
I add another entity like this as described in the documentation linked above:
  entities:
    track: true
  - device_id: test
    track: true
    search: test
After saving and rebooting, I end up with the original calendar appended to my change and no new entry for calendar.test in the States pages. This is the resulting google_calendars.yaml:
  entities:
    track: true
  - device_id: test
    track: true
    search: test
  entities:
    track: true
What am I doing wrong? If not in the google_calendars.yaml, where and how am I supposed to add a new entry with a search to the calendar?
Thanks!
track_new_calendar
(boolean)(Optional)
Will automatically generate a binary sensor when a new calendar is detected. The system scans for new calendars only on startup.
Default value:
true
Not sure why it is finding another calendar. The first thing it does when it finds a calendar is check if the cal_id already exists…
    def _found_calendar(call):
        """Check if we know about a calendar and generate PLATFORM_DISCOVER."""
        calendar = get_calendar_info(hass, call.data)
        if hass.data[DATA_INDEX].get(calendar[CONF_CAL_ID], None) is not None:
            return
Just checking, you’re not changing the cal_id hopefully.
You could try changing the track_new_calendar to false. It will stop it from adding another one, but not sure if the problem is something bigger than just having a duplicate…
google:
  client_id: YOUR_CLIENT_ID
  client_secret: YOUR_CLIENT_SECRET
  track_new_calendar: false
Thanks for your answer!
You confirmed that my approach should have worked, that was an important step :slight_smile: I only changed the cal_id for the example I gave here.
Setting the track_new_calendar to false did nothing, that confirmed your suspicion that something bigger was going on.
I redid the setup (including creating new credentials for google) and now it seems to work.
And thanks for the idea to check the source itself, will do that next time!
