I moved over to HassIO from Hassbian and copied my old configuration.yaml file across when I did that. However, I was logged in to a different google account at that time and it has associated my google calendar component with that account rather than the one I want it to.
So far I have tried;
Changing the e-mail address in the entity itself, but it reverted back.
Deleting the google calendar component from my configuration.yaml file and deleting the google_calendars.yaml file and restarting home assistant. Then adding the google calendar component back to my configuration.yaml file, making sure I was logged in with the correct google account and restarting home assistant again.
It is still coming up with the wrong google account and not the one I want to use with home assistant. I am thinking the entity needs to be removed and it must need to be deleted from elsewhere (possibly somewhere in the home-assistant_v2 database file)
Did you copy over the file .google.token ? I believe that’s where the authentication token is stored. I imagine that deleting that file will put you back on the right path.
I have looked at the files I backed up before moving to HassIO and .google.token was not one of them, so I couldn’t have had that previously when it worked.
I do have that file now, but I have installed the google assistant addon and it appears to contain data relating to that.
Resurrecting an old thread here because I think it may be similar to my issue.
My Google Calendar setup got screwed up somehow (HA stopped seeing my calendars) so I decided to start the whole process over again. I have even deleted my HA project from Google and created a new one, new Google Assistant and Calendar setup. The problem is that HA is still not seeing my calendars and I think its because the Authorisation pop-up never came through as per the last section of the below instructions.
After playing around with the .google.token file and seeing what effect that has I think my issue is that I need to find a way to re-trigger Google to request authorisation from HA again. Is there a way to do this?
Ok, so I worked it out. deleted the .google.token file, went into the Google API Console and re-saved the Oauth consent. Restarted HA and it brought up the Google login request. All good now
I recognize these days the same issue. With deleting the token and reauthorization I can fix it, but that’s not acceptable to do every or every second day…
I really like my google calendar integration but I am having the same issue with having to reset the token. Seems that it needs done with increasing frequency.
I can’t even complete the initial configuration, after entering the google credentials, I just got the error:
Authentication code expired, please restart Home-Assistant and try again
Also I can’t find any google_calendars.yaml or .google.token files in my config folder.
I use HA from the virtual machine image, if this makes a difference.
