Google Calendar Multiple Events
Using the Google Calendar integration and unfortunately it’s only showing a single event within the calendar.xxxx_calendar entity.
Here’s the /calendar URL as seen from clicking on the sidebar:
This clearly / correctly shows the two events occuring today. However, when I view the underlying calendar.xxxx_calendar entity it shows only the first event:
Thoughts on how to retrieve the second event (even if it requires adding an additional template sensor to do so?).
Thx!
Bump… Any love for multiple all_day events in Google Calendar?
Have you looked at atomic_calendar_revive? It will allow you to see multiple events on the screen.
Not sure how to get the second sensor unless you know search criteria like birthday.
@allenporter
Tried triggering automations based on your new calendar event and getting this error. This is two all-day events triggering at midnight. One-fired correctly. The other gave this error…
The mode for the automation is set to single, which cancels a second event if it fires at the same time. I believe you need to set a mode of either queued or parallel.
Nice catch. Ty. Updated and will advise if it doesn’t work - though assuming it will - thx again!
