Google Calendar not working
Hi all,
I’m trying to get the Google Calendar custom card to work in my Home Assistant installation, but I can’t get it to work.
  1. I’ve added the calendar-card.js file to my /www/ folder,
  2. Added this line to my lovelace-ui.yaml
    resources:
    • url: /local/calendar-card.js?track=true
      type: module
  3. Authorized the Calendar to work with HA
  4. Added this to my configuration.yaml
    google:
    client_id: 2**************gfs.apps.googleusercontent.com
    client_secret: Y
    d
  5. Restarted Home Assistant and then, when it still didn’t work, rebooted the entire system.
I get as far as the ‘google_calendars.yaml’ being created, but I can’t add a calendar card. The calendars actually show up under ‘Unused entities’ but, beyond that, nothing.
When I try to add
type: 'custom:calendar-card'
I’m informed that the custom entity doesn’t exist.
I followed these instructions, to begin with
Hopefully someone can point me in the right direction.
What was the procedure you used to get the calendar-card.js into your www folder?
I have my HA config folder shared via smb, so I just copied it from my Windows PC.
Ok, then what was the procedure you used to get the file on to your windows pc?
What I’m asking is did you clone the github repo then move the cloned file to your HA www folder, or did you copy the contents of the file from the github code section and paste them into a file on your pc or did you copy the contents ofvthe github file in the raw format and paste that into a file on your pc?
I think that’s my mistake, I just downloaded it from the files list with a right-click.
I’ve now cloned the project from GitHub and am attempting the whole process again.
Edit: Scratch that, it still doesn’t work.
post the entire lovelace config for the card. make sure you properly format it so we can see the syntax.
Just reading what you wrote gives me the feeling I’m doing something wrong; like I’ve missed a step somewhere, although I can’t imagine where. The only thing that isn’t 100% clear is the part about adding the custom card to views.
I’ve added my ui-lovelace below (I hope I’ve done the formatting right)
resources:
  - url: /local/calendar-card.js
    type: js
  - url: /local/custom_ui/dark-sky-weather-card.js?v=4
    type: js
  - url: /local/custom_ui/mini-media-player-bundle.js?v=0.9.8
    type: module
  - url: /local/custom_ui/tracker-card.js?v=0.1.5
    type: js
  - url: /local/custom_ui/surveillance-card.js?v=0.0.1
    type: module
  - url: /local/custom_ui/mini-graph-card-bundle.js?v=0.1.0
    type: module
  - url: /local/custom_ui/card-modder.js?v=fadc03
    type: module
  - url: /local/custom_ui/slider-entity-row.js?v=d6da75
    type: js
  - url: /local/custom_ui/card-tools.js?v=6ce5d0
    type: js
  - url: /local/custom_ui/compact-custom-header/compact-custom-header.js?v=0.2.7
    type: js
  - url: /local/custom_ui/waze-card.js?v=1.1.1
    type: js
  - url: /local/custom_ui/circle-sensor-card.js?v=1.2.0
    type: module
  - url: /local/custom_ui/monster-card.js?v=0.2.3
    type: js
  - url: https://unpkg.com/[email protected]/moment.js
    type: js
#                                                               VIEW 0 - HOME                                                               #
  - id: 0
    icon: mdi:castle
    background: center / cover no-repeat url("/local/lovelace/background-15.gif") fixed
    cards:
      - id: 8ddb8b8a69b6431f813e8e364b73bb35  # Automatically created id
        type: vertical-stack
        cards:
          - type: custom:card-modder
            card:
              type: entities
              title: Days Remaining
              show_header_toggle: false
              entities:
                - sensor.valentines_day
                - sensor.easter_camping
                - sensor.jackson_bday
                - sensor.mother_day
                - sensor.tina_bday
                - sensor.hudson_bday
                - sensor.bali_trip
                - sensor.anniversary
                - sensor.xmas_day
                - sensor.days_left
# Kodi Remote
- title: Kodi
  cards:
   - type: vertical-stack
     cards:
      - type: entities
        entities:
          - media_player.kodi
      - type: horizontal-stack
        cards:
        #PREVIUOS
          - type: entity-button
            icon: mdi:skip-previous
            entity: script.kr_prev
            tap_action:
              action: call-service
              service: script.turn_on
              service_data:
                entity_id: script.kr_prev
            hold_action:
              action: none
        #STOP
            icon: mdi:stop
            entity: script.kr_stop
            tap_action:
              service_data:
                entity_id: script.kr_stop
            hold_action:
              action: none
        #PLAY PAUSE
            icon: mdi:play-pause
            entity: script.kr_play_pause
            tap_action:
              service_data:
                entity_id: script.kr_play_pause
            hold_action:
              action: none
        #NEXT
            icon: mdi:skip-next
            entity: script.kr_next
            tap_action:
              service_data:
                entity_id: script.kr_next
            hold_action:
              action: none
        cards:
        #HOME
            icon: mdi:home
            name:
            entity: script.kr_home
            tap_action:
              service_data:
                entity_id: script.kr_home
            hold_action:
              action: none
        # UP
            icon: mdi:menu-up-outline
            name:
            entity: script.kr_up
            tap_action:
              service_data:
                entity_id: script.kr_up
            hold_action:
              action: none
        # EMPTY
            icon: mdi:file-excel-box
            name:
            entity: script.kr_down
            tap_action:
              action: none
            hold_action:
              action: none
        cards:
        # LEFT
            icon: mdi:menu-left-outline
            name:
            entity: script.kr_left
            tap_action:
              service_data:
                entity_id: script.kr_left
            hold_action:
              action: none
        #SELECT
            icon: mdi:circle-outline
            name:
            entity: script.kr_select
            tap_action:
              service_data:
                entity_id: script.kr_select
            hold_action:
              action: none
        #RIGHT
            icon: mdi:menu-right-outline
            name:
            entity: script.kr_right
            tap_action:
              service_data:
                entity_id: script.kr_right
            hold_action:
              action: none
        cards:
        #BACK
            icon: mdi:undo-variant
            name:
            entity: script.kr_back
            tap_action:
              service_data:
                entity_id: script.kr_back
            hold_action:
              action: none
        # DOWN
            icon: mdi:menu-down-outline
            name:
            tap_action:
              service_data:
                entity_id: script.kr_down
            hold_action:
              action: none
        # EMPTY
            icon: mdi:skip-next
            entity: script.kr_playlist
            tap_action:
              action: more-info
              service_data:
                entity_id: script.kr_playlist
            hold_action:
              action: none
resources:
  - url: /customcards/github/custom-cards/tracker-card.js?track=true
    type: module
I see a few things…
it looks like you have two views - one that just has an icon (castle) & no title and the second one has a title only (kodi). Not a problem but just clarifying what I’m seeing.
the spacing and indentation is off but i don’t know if that’s a copy/paste thing or not.
you have two “resources:” sections. one at the top & one at the bottom. combine those two into one. as far as i know you can only have one.
I don’t see where the config is for the calendar card? Am I missing something?
I think I have a lot of extra/unnecessary info in my ui-lovelace; I basically just copied it from another I liked.
From what I can see, I’m indeed missing the configuration for the calendar-card; but I don’t see anywhere how I should do it.
I’ve tried adding this, to my raw-config:
  - type: custom:calendar-card
    title: "My Calendar"
    progressBar: true
    entities:
      - calendar.my_calendar
which creates a blank card for the calendar, but without content.
