Does anyone know how to add the new google cameras to Homeassistant, i have all the Nest cameras working but i cant see the new indoor camera
You need to set up the google nest integration, there are a couple of good step by step videos on YouTube. Word of warning, save all your codes to a notepad or something makes adding stuff a lot easier.
i have the Nest camera’s working fine, the issue is the newer cameras are google and use the google home app how do i get that camera set up
I have both new and old nest cameras, I deleted the integration, then reinstalled it and it found all of them even the decking camera that is the new battery one. Make sure you have all your auth codes from the API before you start.
