I cant find how to trigger an Automation based on when the volume level changes on Android TV / Google cast device?
I know its possible, my Homeseer system does it.
thx
thx
Yes it’s 100% possible, but you most likely need to define template sensors to relay if the volume is turned up or down. a simpler method may be to created scripts for volume + and - and then have the automation react to the execution of those scripts.
This is a simple example to turn off a light if the volume is adjusted
alias: Example
description: ""
triggers:
- trigger: state
entity_id:
- media_player.your_cast _device
attribute: volume_level
conditions: []
actions:
- action: light.turn_off
metadata: {}
data: {}
entity_id: light.your_light
Script Example
alias: New automation
description: ""
triggers:
- trigger: state
entity_id:
- script.volume_down
conditions: []
actions:
metadata: {}
data: {}
entity_id: light.pc_spot
mode: single
Thank you, I could not find that. I really want to know what the volume level is… the number itself since I like to ensure its not turned up past 30, and in the morning past 20.
Its unfortunate that many of the default Integrations are half-baked.
I see now! Let me try to isolate the cast device’s volume level. HA knows the volume level, but it’s not a straight forward attribute.
Nevermind, it’s available
volume_level: 0.5400000214576721
{{ state_attr('media_player.cast_device', 'volume_level')}}
awesome, thank you! I’ll report back once I have some stuff running
You can create a template sensor as an entity or simply template the trigger in the automation. Quite a few ways! Let me know ![]()
{{ state_attr('media_player.your_cast_device', 'volume_level') < 0.3 }}
OK, it created the template sensor entities. They show ‘Unavailable’ … Does it need to get new data before that status goes away?
template:
- sensor:
- name: "Living Room TV Volume"
state: >
{% set volume = state_attr('media_player.googletv_livingroom', 'volume_level') %}
{% if volume is not none %}
{{ (volume * 100) | round(0) }}
{% else %}
{{ states('sensor.living_room_tv_volume') }}
{% endif %}
unit_of_measurement: "%"
icon: mdi:volume-high
availability: >
{{ has_value('media_player.googletv_livingroom') and state_attr('media_player.googletv_livingroom', 'volume_level') is not none }}
also looks like I can set the volume using this
- service: media_player.volume_set
entity_id:
- media_player.googletv_livingroom
volume_level: 0.98
For the automation you can use a template trigger like this as a test
description: ""
triggers:
- trigger: template
value_template: "{{ state_attr('media_player.googletv_livingroom', 'volume_level') < 0.3 }}"
conditions: []
actions:
metadata: {}
data: {}
mode: single
Understood… I also wanted to see the volume level in an Entity. Easier to see a number vs a slider.
You’d round it this way if you are trying to template a sensor
{{ (state_attr('media_player.shield', 'volume_level') *100) | round(0)}}
Yes, no need to add a UOM, just deal with comparing straight values.
A good way to review the logic outcome is the Template editor in Developer Tools
{{ (state_attr('media_player.googletv_livingroom', 'volume_level') *100) | round(0)}}
{{ (state_attr('media_player.googletv_livingroom', 'volume_level') *100) | round(0) < 18}}
