I’m trying to cast a lovelace dashboard to my Google hub displays (I have one original Hub and one Hub Max).
It took me a few tries to get the syntax correct in the Developer Tools ‘Call Service ‘ tab , but after a few tries I found the correct url and view path and the default_view dashboard showed up on my Google Hib Max display.
But after that, no more calls will show on the display. I created a script to cast a different dashboard to my other Google display, and that worked. But none of the buttons navigating to other dashboards worked. As with the first display, casting no longer works after that first load.
There were no errors shown for the script, but I’m getting the following in my logs
Logger: custom_components.googlewifi
Source: custom_components/googlewifi/__init__.py:171
Integration: Google WiFi Integration ([documentation](https://github.com/djtimca/hagooglewifi), [issues](https://github.com/djtimca/hagooglewifi/issues))
First occurred: 7:13:33 PM (5 occurrences)
Last logged: 7:15:33 PM
Unexpected error fetching GoogleWifi data: Session is closed
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 250, in _async_refresh self.data = await self._async_update_data() File "/config/custom_components/googlewifi/__init__.py", line 171, in _async_update_data system_data = await self.api.get_systems() File "/usr/local/lib/python3.10/site-packages/googlewifi/__init__.py", line 188, in get_systems response = await self.get_api(url, headers, payload) File "/usr/local/lib/python3.10/site-packages/googlewifi/__init__.py", line 63, in get_api async with self._session.get( File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1141, in __aenter__ self._resp = await self._coro File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 400, in _request raise RuntimeError("Session is closed") RuntimeError: Session is closed
Is there a “session” that I need to reset each time I cast a dashboard? Will that fix the issue with the navigation buttons not working or is that a separate issue (I’m guessing it’s related)
Edit: just a note, I haven’t configured any “known hosts” or “allowed UUIDs”, I’m using what’s auto discovered. If I need to do that, I’ll give it a try.
Edit #2: after installing a couple of updates, I checked again to see if a restart would reset this issue, but the dashboard still doesn’t show on the display.
