I have a home-assistant installation running under docker (not hassio) and would like to cast a lovelace view to my Google Nest screen. I followed the instructions from the Google Cast topic at: https://www.home-assistant.io/integrations/cast/, but until now every attempt failed, after calling my script that should start the cast.
The discovery of the cast device did seemed to succeed (the youtube cast sample did succeed):
2021-02-22 07:15:47 DEBUG (zeroconf-ServiceBrowser__googlecast._tcp.local._16336) [homeassistant.components.cast.discovery] Discovered chromecast ChromecastInfo(services={'Google-Nest-Hub-b1995e807b8236cc3ab8cdf42e22feee._googlecast._tcp.local.'}, host='192.168.64.185', port=8009, uuid='b1995e80-7b82-36cc-3ab8-cdf42e22feee', _manufacturer='Google Inc.', model_name='Google Nest Hub', friendly_name='Nest', is_dynamic_group=None)
2021-02-22 07:15:48 DEBUG (MainThread) [homeassistant.components.cast.media_player] _async_create_cast_device: ChromecastInfo(services={'Google-Nest-Hub-b1995e807b8236cc3ab8cdf42e22feee._googlecast._tcp.local.'}, host='192.168.64.185', port=8009, uuid='b1995e80-7b82-36cc-3ab8-cdf42e22feee', _manufacturer='Google Inc.', model_name='Google Nest Hub', friendly_name='Nest', is_dynamic_group=None)
Here is the error that i receive in my log:
2021-02-22 07:16:21 INFO (MainThread) [homeassistant.components.script.cast_on_nest] Cast Screen on Nest: Running script sequence
2021-02-22 07:16:21 INFO (MainThread) [homeassistant.components.script.cast_on_nest] Cast Screen on Nest: Executing step call service
2021-02-22 07:16:21 ERROR (MainThread) [homeassistant.components.script.cast_on_nest] Cast Screen on Nest: Error executing script. Error for call_service at pos 1:
2021-02-22 07:16:21 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1033, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 246, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 254, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 464, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1455, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1490, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 665, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/cast/home_assistant_cast.py", line 44, in handle_show_view
hass_url = get_url(hass, require_ssl=True, prefer_external=True)
File "/usr/src/homeassistant/homeassistant/helpers/network.py", line 123, in get_url
raise NoURLAvailableError
homeassistant.helpers.network.NoURLAvailableError
My script looks like:
script:
cast_on_nest:
alias: Cast Screen on Nest
sequence:
dashboard_path: lovelace
entity_id: media_player.nest
view_path: casting
service: cast.show_lovelace_view
cast_youtube_to_my_chromecast:
alias: "Cast YouTube to My Chromecast"
sequence:
- target:
media_content_type: cast
media_content_id: '
"app_name": "youtube",
"media_id": "dQw4w9WgXcQ"
service: media_player.play_media
So the cast_on_nest fails and the cast_youtube_to_my_chromecast succeeds.
I have a Nabu Casa cloud account and followed instructions mentioned here: https://www.home-assistant.io/more-info/no-url-available/
Other things I tried are:
- Reinstalling the Google Cast integration
- Other cast devices (Chromecast)
- use mdns-scan on the docker host
- verified the net-host option in my docker-compose file
- tried some other lovelace views
- Start the script while i was connected to the Nabu Casa cloud of my installation
Anyone has some tips to get this working?
