Since moving my Hassio configuration over to docker I’ve been having issue with my Google Homes disappearing. I’m using Docker Compose and have the container connected to the host network.
What I’ve found is that the container can see ALL networks on the host including all bridge networks for other containers. It appears that Home Assistant is not using the right IP range to send the broadcast packets for discovering cast devices.
Here’s how I’ve came to this conclusion.
Get a bash console into the Home Assistant container
docker exec -it home-assistant /bin/bash
Install tcpdump
apk add tcpdump
Run tcpdump filtering for cast data. From the home assistant UI try to enable the Google Cast integration.
tcpdump | grep cast
What I see is:
18:43:05.058008 IP 172.17.0.1.5353 > 224.0.0.251.5353: 0 PTR (QM)? _googlecast._tcp.local. (40)
My home network is on a 192.168.0.0/24 subnet and I believe the above output confirms the Home Assistant is using the default bridge network for it’s cast detection.
By running ip a | grep inet I can confirm that home assistant can see all host networks.
ip a | grep inet
inet 127.0.0.1/8 scope host lo
inet 192.168.0.12/24 brd 192.168.0.255 scope global eno1
inet 172.19.0.1/16 brd 172.19.255.255 scope global br-c2e8e6550627
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
inet 172.18.0.1/16 brd 172.18.255.255 scope global br-14c08394512f
Has anyone else came across this or know how to block/hide other host networks from home-assistant? Or force it to use the correct 192.168.0.0 range as it’s default?
As a follow up to this. Launching the Home-Assistant container in privileged mode solved the issue. Not instantly. But within 24 hours I had a popup that cast devices had been found.
Can you share the commands you used to launch the homeassitant container in privileged mode? The supervisor and version containers are already running in priv mode. I assume I would just need to change the hassio-dns container (which is not running in priv mode) to get this to work.
Here are my Hassio containers that are not addons.
a310cf1aa202 homeassistant/amd64-hassio-dns:1 “coredns -conf /conf…” 5 hours ago Up 5 hours hassio_dns
0703fe7514da homeassistant/amd64-hassio-supervisor “/bin/entry.sh pytho…” 2 weeks ago Up 5 hours hassio_supervisor
cc8259450c51 homeassistant/qemux86-64-homeassistant:0.103.4 “/bin/entry.sh pytho…” 4 weeks ago
Sorry if this is a basic question, I am new to docker and google was not helpful in figuring out how to launch a container in priv mode. Also will this change stick on reboot?
Weird because I am getting the same results that you are. I have a dedicated network for IoT devices vlan 30. My hassio, running as a vm, has interfaces on my primary network (vlan 10) and on vlan 30. Google cast cannot discover any devices, all of which exist on vlan 30. I can manually add them and they work. when I run tcpdump | grep cast I get the exact same result as you which lead me to believe that your fix may work especially since the container labeled dns was not running in privileged mode. Do you have any ideas?
My homeassistant network has not changed, I run it from 192.168.68.134, my casts are 192.168.68.140 and 192.168.68.147, been running them for over 2 years and they suddenly stopped showing, I miss my automations, is there a way of forcing them in the config? I tried :
I also have an issue with Google Home devices (few minis and one hub) - I’m building a new install of HA.
HA-Core in docker. Network mode is host, but integration doesn’t find no one of devices.
So the problem is solved and was very stupid. I’m running HA core on docker container (network_mode: host) inside KVM Guest Ubuntu machine. So the problem is that by default KVM is not forwarding multicast traffic to guest machines.
Can I ask why you’re not using Hassid on KVM? I use docker on the host and have around 50 containers. After the recent (retracted) announcement I moved to HassOS on KVM. I prefer it as it keeps home assistant free from my meddling with docker and it stops home assistant messing with docker swarm.
I had the same problem. When you create the docker you need to set network mode to host. So if creating docker on command line add “–net=host” to the command line.
I guess my response wasn’t all too clear. I was stating that my solution was opening that firewall port on the host level. I troubleshot this for about 2 days and solved it by opening the port. I posted my solution here in case anyone others weren’t aware that 5353 needed to be accessible at the host level since it’s not anywhere in the installation documentation. After I openined that port on my hosts firewall my devices were detected instantly.
So for those of you who are using Google Cast and reverse proxy, how are you doing it? Sounds like I need to have this container on host to use the googles, and on another network simultaneously for letsencrypt/etc (which is not possible when using host). Maybe I just don’t know enough about configuring my proxy conf to make this work
