Hello!
I’m trying to make myself some room views to be avalible on my nest hub by voice activation.
I’ve got the code up and running and preparing for voice support but im stuck with this problem that
after a while… my nest hub/home assistant seems to forget my rooms exist untill I reboot my nest hub then all is fine an dandy. Not a workable solution though.
What am I missing??
Also my nest hub is currently setup to show photos when not in use, which seems to disable my cast and block further casts. Will try disabling that ofc.
Edit:
Doing a media_player.turn_off pulls my hub out of the “unable to find view with path…” and
my casting works again.
Question: Is this a must?
My input_select
google_cast_rooms:
name: Google Cast Rooms
options:
- "vardagsrum" #livingroom
- "kok" #kitchen
initial: "kok"
icon: mdi:home
My scripts featuring
- Next screen
- Previous screen
- Screen by “parameter in”
- Show livingroom
cast_next_room:
alias: Cast|Hubben|Next
sequence:
- service: input_select.select_next
entity_id: input_select.google_cast_rooms
- service: cast.show_lovelace_view
dashboard_path: lovelace-rum
entity_id: media_player.hubben
view_path: "{{ states('input_select.google_cast_rooms') }}"
cast_prev_room:
alias: Cast|Hubben|Previous
sequence:
- service: input_select.select_previous
cast_by_param:
alias: Cast|Hubben|Param
description: "Cast Param to Hubben"
fields:
param:
description: "Room name as found in input_select.google_cast_rooms"
example: "vardagsrum"
sequence:
- service: input_select.select_option
option: "{{ param }}"
- delay: 1
cast_livingroom:
alias: Cast|Hubben|Livingroom
variables:
target: "vardagsrum"
description: "Calls Cast|Hubben|Param with preset parameter"
sequence:
- service: script.cast_by_param
param: "{{ target }}"
