Google changing constantly breaks things
As some of you already know google changes the voice assistant a lot lately, which is kind of disturbing me cause it breaks things. Last update i had i needed to change the google api settings and reconnect homeassistant to my phone before it started working again. anyway, all google routines are empty, at least, the checkboxes of what it needs to do are all unchecked cause i had to re-pair the connection between google and home assistant. I had a lot of routines set up and i all need to do them again.
How do you feel about this? Should i setup routines again, with the change of breaking later + i need to setup routines on all house phones, or do some more automation in home assistant instead? Its hard to make a choice cause im not sure which path home assistant is going to. I mean last update it broke my secrets.yaml… out of the blue the while system stops cause of an update, yes i do appriciate time and effort devs put in this, but please dont become a new Microsoft with constantly ailing updates which makes bsod.
I have read somewere the secrets.yaml will come back with lovelace but im not sure?
Anyway, any suggestions whats my best move atm?
That’s a Google caused problem not Home Assistant. Devs of HA components cannot predict what API changes other companies will make unless they’re notified by them in advance.
secrets.yaml are completely unrelated to the web gui you are using in home assistant
Use Home Assistant cloud component to connect to Google Assistant
