would appreciate it. How do you tell if hardware acceleration is being used? I have the same issue where CPU usage is the same regardless of what settings are in the LXC conf files. I don’t have a coral (yet) so am just looking at re-encoding and recording and have detection turned off.
EDIT: I finally managed to get hardware acceleration working (as shown in intel_gpu_top) but it has made a difference (going from 5% to about 3.5% CPU on my pentium J5005) with no detection of course.
Intel_gpu_top is how I checked too. Didn’t really make much difference for me though. Mine is sat at around 8% when it’s quiet but we live next to a school… When the traffic turns up for that it hits about 35%! With detection on obviously.
I have just finished setting up all this “stuff”, not without struggling a lot…
But it seems working very very nice.
I don’t know much about lxc, proxmox and mount points and now i have a big problem about clips files.
The question is: where are them located? And how to let them out from the lxc container and make them recording on a lvm disk?
Yes and it works. Global Unichip Corp will change to Google Inc when you first run Frigate with TPU config on it. Then restart Proxmox and you will see Google Inc against Global Unichip Corp
Check my original post at the top of this thread: “Appendix C - Frigate Recording Storage”.
If you follow that guide, you can map a ZFS share from any physical drive into your LXC, and then you edit your docker file (using Portainer) to map that LXC mount into your docker image as “/media/frigate” (the default location for the clips etc).
I dont believe you. Can u try it with a new lxc? There are so many obstacles on the way. For example the underlines in the quote for the portainer settings. Im new on docker and so thats all new for me (for the other users: remove the underlines…)
When you first run frigate or when you configure it with the TPU as per google coral website? As i did that (the TPU) and it still shows up in VMware as ‘global unichip’ etc.
After a long drought, they are starting to show up on EBay for more reasonable prices. I suspect the manufacturers’ back orders must be getting close to shipping - so the scalpers are trying to unload.
If U running Proxmox, after U configure Coral in Frigate’s config, U have to restart Proxmox to read devices again by Proxmox. Than it’ll change from “global unichip” to “Google Coral Inc”.
Proxmox has been updated and I believe nesting is only available if it’s set to unprivileged. So, does anyone have any update on how to do a passthrough for this?
Anyway, I’m running Debian 11 as my base installation. Any help will be greatly appreciated.
